Threads: 531
City: Jackson, NJ
House GND is the Earth GND.
A waterpipe is a good one.
Or the GND pin in the power outlet.
Threads: 4
City: USA Lincoln, CA
(03-03-2015, 04:11 PM)Radioroslyn Wrote: Earth ground is best. Shouldn't blow gfi or breaker unless the cap that from the ac line to the chassis is bad.
Thanks Terry.
Threads: 4
(03-02-2015, 02:08 PM)Jay Thomas Wrote: (03-02-2015, 12:34 PM)Bill Bacco Wrote: If you are interested in some changes I made to my 81 Jr to address the volume issue, check out the following thread.
http://philcoradio.com/phorum/showthread...2#pid38812
Bill
Thanks Bill. May be the next thing I will try. This seems to put the volume control in the output circuit where later models have them.
Jay
Hi Bill:
I made the changes in your diagram to my delight! Grounding the receiver was not an option for me. With the circuitry change I can now control the volume from zero to loud on the strongest stations. I do not notice any distortion at any volume level and I now receive more stations than I did before the changes. Amazing! Thanks much!
Jay
Threads: 266
If you would like to raise the sensitivity that 1.2k resistor seem a bit low unless you have a 50,000w AM blowtorch near. The original was 20k. I'd play with that value. Try 5,10,15K. If you live in stickville you can just remove that resistor.
