Threads: 267
City: Bandon
State, Province, Country: OR
Anyone have a better scan of the label that goes on the Sprague electrolytics can? I did a little photoshop on this one but the scan is still off center a bit. When you print it and put it on a can it actually doesn't look so bad since its curved anyway but thought I'd check...and this one will be available until a better one comes along.
[Image:
https://www.dropbox.com/s/tzydgwid1pahvc....jpg?raw=1]
Threads: 212
City: Seattle
State, Province, Country: WA
Thanks for this great restoration thread Bob. I just started on a Philco 50 and your detailed restoration is a great help!
Do you know the pin-outs for the bypass capacitor block (No. 15 - Part No. 03459)? The schematics I've seen (service bulletin #86, Riders, Beitman's) list values but don't label the block or the schematic.
I'll post some pictures from mine soon too.
Threads: 212
City: Seattle
Ah ha - fortunately the 'Internet Way Back' has a reference to the annotated schematic.
https://web.archive.org/web/201603061325...schema.htm
So that helps!
Threads: 267
City: Bandon
Great find! The cap block just had wires coming out of it as labeled on the wayback post.
http://philcoradio.com/phorum/showthread...#pid111946
Threads: 2
City: Spruce Pine, NC
Hey Bob,
I have a phlico 50 that someone has tried to do a restoration.
Wrong Caps & some missing, especially from the #15 Cap Can. There is no can now, which complicates things & tracing the schematic some of those caps are missing.
I know the values for the caps that were in the can.
What I would like to find out is, have you marked a schematic to show which values go to the #15 caps on the schematic?
Thanks so very much for the Help
Jason
Threads: 267
City: Bandon
Jason, I think this will answer your question. Ron has a number of marked up early schematics in the Tech Section.
http://www.philcoradio.com/images/phorum/schem/50.jpg
Threads: 2
Woohoo! Thank you so much Bob. I didn't think to check in the tech section. I am so very grateful to you for pointing me in the right direction.
Now maybe this 50 will actually work with right caps, in the right places.
Thanks Again!
Jason
Threads: 1
City: Victoria
State, Province, Country: BC
Thank you so much. Your method (dare I say ‘trick’?) for opening up the sealed condensers was very appreciated!
My model is a Canadian 50a for the older electrical grid.
ANy thoughts on converting to the current 60hz grid?
Thank you
