Philco VTVM model 7001
Thanks to Sam I found this really neat tester... She is a little worse for wear but she is complete minus the cables.
This little beast is a 4 tuber! That surprised me....
I will have to blast the cabinet and touch up the face paint for looks.
I think the missing tube is a 7Y4? The dial glass is gone also...
I found this article online but no schematic...
http://www.frontiernet.net/~jff/Philco70..._VTVM.html
If anyone has the probes for this I would like to buy a set.
Here is what she looks like.
Yes you are missing the 7Y4, it's the low voltage rectifier. The connector has been changed the except a pl-259 connector (very common connector).  Most vtvm would have a length of shielded cable or coax  with a 1 meg resistor in series with the center conductor going to the tip of the probe. The black connector takes a banana type or pin type connector. The banana is a bit fatter, hard to tell from the pic.
RS used to carry these parts and still may I haven't been to one in a while.
The HV probe is going to take a little guess wurk. Most have a resistors inside the drop the voltage down before it gets to the meter. Your has a large resistor connected to the connector on the backside. When you get it working try measuring a relatively small voltage with it without any resistance in series and see what kind of reading you get. HV probes are big and look like a turkey baster with wires.
hey kirk
here`s great site for test equipment  free too Icon_thumbup
http://plymouthcolony.net/starcity/radio...co7001.pdf
http://plymouthcolony.net/starcity/radio...nuals.html
it`s me
Did you really just say "When you get it working" Icon_lol
I will try and thanks for the info and link
Me
  Here is the one I picked up at the last radio swap meet.
[Image: http://i1336.photobucket.com/albums/o654...giiluo.jpg]
