Threads: 140
City: Lansdale
State, Province, Country: PA
All, I did find that the Screen Resistor on the 6K7 was supposed to be 82 K was reading 120 K.. I replaced it and now the Eye tube is much better. Seems to be responding better. On my strongest station now its almost completely closed.
Skip...
(This post was last modified: 09-06-2016, 03:34 PM by
vecher.)
Threads: 140
City: Lansdale
Ok, Did a complete alignment using the AVC voltage to peak. Made good improvements.. Next is to start on the Cabinet.. Pictures to follow.. Will need help as I haven't never done this before..
Skip...
Threads: 140
City: Lansdale
Threads: 267
City: Bandon
There are products like
Howard's Restora-A-Finish that do some covering of scratches and smoothing of the lacquer finish but they are not miracle workers. It will look a little better for a little while. After a year or so it may need another treatment and it won't add lacquer where there is missing finish. It won't hurt to try it to see if it gives the look you want. There are a variety of colors including oak, neutral, maple, dark oak, walnut, dark walnut and mahogany to use depending on the existing finish.
Threads: 140
City: Lansdale
Ok I tried Howard's Restora-A-Finish.. It worked pretty good. Much better than it was..
[Image: http://i292.photobucket.com/albums/mm38/...ktymnb.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...vrmdkj.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...mdpicy.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...5blcv2.jpg]
I do not know what to do with the dark edging around the top..
Still have to get paint off one side.. But doesn't look to bad for a 77 Year old radio..
Skip...
Threads: 267
City: Bandon
Threads: 140
City: Lansdale
Yup, If the top looked as good as the sides I would be in business..
Skip..
Well I think I will put radio back in to see how it looks.. and sounds..I can always take it out again if I need to do more to cabinet..
Skip...
