Threads: 14
City: Idaho Falls, Idaho
http://rs32.pbsrc.com/albums/d5/flathead...0&fit=clip
Here's a photo of the ever elusive parts number page for this set, mine shows a different part number from the 2766, mine shows a 2848, is this the same opt?
(This post was last modified: 09-18-2016, 07:56 PM by
flatheadjr.)
Threads: 14
Tried to open that thread, it says it doesn't exist
Go to Philco Downloadable Files then Philco free download files it's in there under spkr zip file
Threads: 267
City: Bandon
Here's the link directly to the speaker file:
http://www.philcoradio.com/phorum/attach...p?aid=5181
It should directly download the speakers.zip file to your PC, then you need to unzip it to read it.
Threads: 14
I finally found it and downloaded it, however last night I pulled the opt up to get a better look at it and have 2 loose solder joints. I don't know if this is the problem or not but I'll re solder and try again.
Threads: 14
So I've gone back and soldered the broken contacts on the speaker to see if I'd get a different reading, it didn't seem to change the readings or voltages on the 45 tubes so it looks like I am now on the hunt for either a new speaker assembly or a new functioning output transformer. What's going to be the best way try to see if anything comes across ebay eventually or try a looking for ad?
Threads: 14
Where did the rest of the thread go?
