Guest Join UsHello Guest,
Please feel free to join us!
Unlock sections of the Phorum that non-members cannot see.
Sign up for Phorum membership today! or Register
Desoldering tool
I found this on Ebay. Has anyone used this or something similar? I went to replace a solder sucker that shot across the room in about 3 different directions and found this. It looks it would work nice on our electronic repairs and restorations. Any thoughts either way?
https://www.ebay.com/p/US-Local-Ship-S-9...0005.m1851
Also found this smaller desoldering tool: https://www.ebay.com/itm/30W-Electric-Va...0005.m1851
Tim P.
Remember the real reason for the Season. Luke 2:1-20 Without the birth of Christ, we wouldn't have Christmas...
Reply
Tim
I don't know what the heck that first dohickey is, but the second is a perfect way to ruin a PCB pad.
Reply
I could see it doing that. Normally I use solder wick on a PC board unless there is some big blob. The 1st is a pistol grip version, like a soldering gun vs a pencil iron. I was thinking it may be nice for those wads of solder we get into on some of these hand wired chassis.
Tim P.
Reply
Tim, I would be leery of the pistol grip unit on eBay.  The trusted name in affordable desoldering stations is Hakko, but it will be 2-3x as much as the one in your link.  They are geared more for PCB work and I read where they tend to clog when doing big clumps like you mention.
For years I used solder wick and various small aluminum bodied solder suckers that worked OK.  Then a few years ago I splurged and bought a U.S. made Edsyn Soldapullt DS017:
http://www.edsyn.com/product/DS017.html
https://www.ebay.com/itm/Edsyn-desolderi...SwbF1aEku2
The DS017 works great and has readily available replacement tips and O rings.  I still use braid also, but the Edysn was one of the best $21 I've spent.
Reply
Yes, I remember those. I used to have one years ago, but forgot what it was called (the name). I think I bought one from a parts distributer that used to service us. Remember the days when the wholesaler parts distributers used to come by the shop a couple times per week to fill orders? Wow! Anyway, I do remember those being good tools. I take it, those heated tools are not very good?
Tim P.
Reply
They serve their purpose... but not for everything.
Reply
(01-03-2018, 09:51 AM)Eliot Ness Wrote: The DS017 works great and has readily available replacement tips and O rings.  I still use braid also, but the Edysn was one of the best $21 I've spent.
Thanks for the tip John! I've ordered one. Icon_thumbup
Reply
those spring loaded solder suckers are not the best idea.
thier diameter profile reduce your visual view and the tip lenght reduces your reach.
I to use solder wick but i am rarely impressed by it because of the long period of time you spend putting heat on the object/area/solder run. it does have its application though but on touchy areas i am forced to be very careful with it
the long nose hot air variety with a foot pedal are best. they wont be 20$ though but they are the best.
Best meaning they do the correct desolder job for the application. you melt and suck out the solder in one motion with the absolute least amount of time and heat on a pieces part.
for onezie twozie desolder tasks i would be all over a manual desolder sucker cheapy spring loaded one if the sucker nozzel was longer and better than what they make now.
perhaps you could modify your manual spring loaded one with a hollow metal tube tip that would give you a skinny 3'' reach ???
still the disadvantage is you have to come into the work area with two things,, the solder gun to heat and the sucker to suck.
Reply
(01-12-2018, 10:38 AM)jcassity Wrote: ....... I to use solder wick but i am rarely impressed by it because of the long period of time you spend putting heat on the object/area/solder run.......
I've found over the years that some soldering braid works much better than others.  A little extra liquid flux tends to also help.
Quote:.......the long nose hot air variety with a foot pedal are best.  they wont be 20$ though but they are the best.
Unfortunately many of us can't justify the cost of that type of desoldering station for hobby use.   When I worked in the field repairing medical equipment we were also limited to what was available to us.  We became very adapt at using a quality Weller or Ungar pencil along with solder  wick and solder suckers.
There were a few times when I tossed my Weller soldering station in the van, but desoldering was always wick and solder suckers, and my favorite became the DS017, although for many years the generic smaller aluminum bodied ones worked OK.
My late brother built one out of an old shark vacuum cleaner his wife had around.  Although I never actually tried it, I did see it when I was clearing out his shop for my sister-in-law.  That was one of the few items from his shop that I left behind...... mainly because his wife exclaimed, "that's what happened to my little vacuum cleaner"   Icon_e_wink
Reply
About Philco Phorum
The Philco Phorum is a family-friendly place for the discussion of Philco radios and related items.
Please feel free to join us! Unlock sections of the Phorum that non-members cannot see. Sign up for Phorum membership today!
           Quick Links
