Threads: 9
City: New York, NY
I recently acquired a Philco model 70, the serial number is A22192. How early is this in the production run? It does have the copper Mershon capacitors. Also, one of the 24A tubes was replaced with a 35, should I replace it with a 24A. The radio works great with lots of volume! Thanks.
Threads: 9
City: New York, NY
Threads: 69
City: Linn Creek, MO
Nice clean chassis!
Could you tell any difference in the operation after replacing the 35 tube with a 24A? I have often wondered why Philco didn't use type 35 tubes in the front end since the volume control varies the bias.
M R Radios C M Tubes
Threads: 112
City: Medford OR (OR what?)
(03-20-2018, 10:19 AM)Steve Davis Wrote: Nice clean chassis!
good point
Threads: 266
From what I've read the 24A doesn't lend it's self to being controlled by varying the control grid voltage hence it doesn't work well in a set w/avc. The 35 has a different cutoff range of voltages that will have a greater effect on it's gain.
Threads: 9
City: New York, NY
