Post Reply
  • 0 Votes - 0 Average
Philco 87 questions
11-02-2011, 12:47 AM
Post: #16
Re: Philco 87 questions
DKinYORKpa Wrote:Great....thanks.....I did notice a rusty, tubeless Philco 87 chassis on eBay for $24.99, 100 miles from me. I suppose that if that transformer was good and I wanted an original look, I could think about that one.
In all likelyhood it won't be good, open primaries on the audio interstage are a common failure with many radios of this era with push-pull 45 tubes not just Philcos. The original interstage is mounted inside a metal cover and the cover is larger then the newer replacements so you could mount the new transformer inside. There was also an article in a past issue od the Old Timer's Bulletin that described how to make a solid state interstage substitute, it's something that I have been meaning to try.
Find all posts by this user
11-02-2011, 03:47 AM
Post: #17
Not a good choice as it is designed to replace odd transformer in an early '20's battery set. use this one. http://www.tubesandmore.com/
Goto transformers/audio and get the Hammond P-T156 it's $17.
Gosh I haven't used a GOTO in a long time!!
11-02-2011, 05:26 PM
Post: #18
Can I assume that the 2.2 mfd caps that AES sells will be OK for the 2.0 mfd caps that go in the cap block?
11-02-2011, 10:19 PM
Post: #19
Yep
11-21-2011, 07:24 PM
Post: #20
So how are you making out with the old model 87?
01-14-2012, 11:26 PM
Post: #21
Quote:So how are you making out with the old model 87?
It was on the back burner and I just tore into it today. The audio transformer replacement went well. It is neatly hidden in the old housing. Then I moved on to the cap tar box. I successfully removed it by coaxing it carefully up and reaching under it and snipping all of the wires and did not have to de-solder and disconnect all of the wires under the chassis. Next was the heat gun on the box. Very time consuming, but it's empty. I'm guessing that I'll next cut a piece of plywood to snuggly fit inside the can with terminal strip(s) to hold all the caps and wires. That's going to take a careful drawing, labeled wires and double-checking Icon_crazy .
01-15-2012, 01:41 AM
Post: #22
Great! Mine started eating 80 toobs. Me thinks one of the new caps has shorted. Did play it alot over the last 6 month or so maybe 5hrs a day.
Post Reply
Forum Jump:
User(s) browsing this thread: 1 Guest(s)
