The PHILCO Phorum
model 29 & 45 label - Printable Version
+--- Forum: Philco Cabinet Restoration (https://philcoradio.com/phorum/forumdisplay.php?fid=9)
+--- Thread: model 29 & 45 label (/showthread.php?tid=25862)
model 29 & 45 label - GRG - 06-29-2025
Good Morning!
I wonder if someone has a file with the label in the picture (3rd) attached for the back panel of this radio they would share.  Thanks.
RE: model 29 & 45 label - IamZoot - 08-19-2025
Did you find the back panel layout you were looking for?
RE: model 29 & 45 label - GRG - 09-29-2025
Not yet thanks.
RE: model 29 & 45 label - IamZoot - 10-04-2025
I did not have much to work with to produce these.  The ones on my radio either did not exist or were in tatters.  So these are not as good as they should be since I had to print out my files that are in a difficult to convert program and then scan.  I noticed that the blue in the "Philco Radio" is not quite as good as it is in my original.  Hope these help.
RE: model 29 & 45 label - klondike98 - 10-04-2025
Hi IamZoot,
Thanks for adding those labels. I'd like to add them to the label section of our digital library. If you get the chance, would you rescan the Tube Layout label. The one in the above post has a portion of the label cut off.
Thanks very much!
Bob
Phorum Mod
I do not know why it should be cut off.  What portion is being cut?  Attached is a new scan.  If this still has a problem I can scan from the opposite direction.  Let me know.
RE: model 29 & 45 label - klondike98 - 10-05-2025
It was part of the topside layout that was cutoff. It looks like the following when I downloaded it. Thanks for helping us on this!!
[Image: https://www.dropbox.com/scl/fi/9wi5f085j5ap6f8ryhsgz/Philco-45-label_cutoff.png?rlkey=s65b9dx893m4f7ipeq6fyiq3x&raw=1]
RE: model 29 & 45 label - IamZoot - 10-05-2025
I guess I should look at what I am sending.  This particular layout was the worst I have ever done.  Nothing good to go by.  About 6 different fonts and one that I had to draw the numbers because they were nothing like any of the 100 or so fonts in my CAD program.
RE: model 29 & 45 label - klondike98 - 10-06-2025
Thank you!
RE: model 29 & 45 label - GRG - 10-07-2025
Thank you so much for this Iam. I very much appreciate the effort.
RE: model 29 & 45 label - GRG - 12-03-2025
For anyone interested, this is the finsihed radio.  https://youtu.be/7p84djodVsY
Thanks agaiin for the help.
