The PHILCO Phorum
Philco 60 Total Rebuild - Printable Version
+--- Forum: Philco Electronic Restoration (https://philcoradio.com/phorum/forumdisplay.php?fid=8)
+--- Thread: Philco 60 Total Rebuild (/showthread.php?tid=26526)
Philco 60 Total Rebuild - Radioguy52 - 05-26-2026
Have a friend trying to rebuild a complete 60:Rewinding coils, etc.
 He asked if he could test the oscillator for function with just the power supply, Det Oscillator Tube and 80 tube.
RE: Philco 60 Total Rebuild - morzh - 05-26-2026
He will need the speaker plugged in. Without Field coil there will be no B+.
The 42 tube is desirable. It will bring the voltages down and will quickly discharge the caps when the radio is off.
RE: Philco 60 Total Rebuild - Steve Davis - 05-26-2026
I'm guessing, the oscillator might work with the other tubes removed, but it might not. The problem I see is voltages are going to be higher than normal because there will not be the load of the output tube. The speaker field coil will have to be connected.
