Threads: 268
City: Bandon
I agree with the spray lacquer. Much closer to the original finish used on these and much easier to strip if things go badly. I usually use DEFT gloss and after serveral, sometimes 6 or 7, coats with some sanding in between if needed I'll rub it out with rottenstone or a fine pumice followed by a paste wax. But that's just me, others have their own steps and produce fine looking end results. DEFT is found in most hardware and big box stores. I also use one of these masks when spraying lacquer, toner and paints.
https://www.homedepot.com/p/3M-OV-P95-Pa.../100653900
Threads: 18
City: West Milford NJ
Threads: 18
I will be replacing the power cord and the one I have has the wide plug on one side does it matter what way it goes on ?
Threads: 21
City: Wellborn Florida
The narrow blade is the hot wire and the wide blade is the neutral. Connect the hot side to the on/off switch be careful working on a AC-DC set they can bite. Best to have a isolation transformer hooked up when working on the set. Take Care David
Threads: 35
City: Roseville, MN
Definitely, the wide spade should be connected to the power on switch so that when the radio is turned on the mains neutral is B-. If you reverse it you will have a hot chassis.
Threads: 18
Thank you very much I wanted to be sure when I replace the cord
