Philco for 1957
Overview
For 1957, the low-end "Philco Transitone" line had disappeared from the Philco radio lineup. Philco also offered far fewer clock radios in the 1957 season, but added an AM-FM model to the line (E976).
After an absence of one year, the high fidelity Phonorama returned to the Philco line as the Phonorama III. The new Phonorama did not include a radio, however - it was only a phonograph. However, a tuner or tape deck could be connected to the Phonorama.
The big news from Philco this season was the introduction of their first all-transistor radio - the T-7.
Model Index
Introduced Summer 1956
Click on a thumbnail to see information and photos for each model:
| E670 | E672 | E675 | E676 | E678 | E740 | E742 |
| E748 | E808 | E810 | E812 | E814 | E816 | E818 |
| E976 | E1351 | E1353 | E1355 | E1356 | E1357 | E1358 |
| E1360 | E1362 | E1363 | E1370 | E1762 | E1763 | E1764 |
| E1765 | E1766 "Phonorama III" | T-7 |
Models
The 1957 Philco Line
Model E670
Four of the five tube-type portable radios offered by Philco during the 1957 season all used four tubes plus a selenium rectifier, and received the AM band only. This is one of the four.
The E670 was available in a black leather cabinet.
Original selling price: Unknown
Number made: Unknown
Model E672
Using the same circuitry as the E670 above, the E672 was available only in green.
Model E675
Another four tube model, this Philco set was available in tan. Like the two portables above, the E675 can operate on AC or DC household current, or on battery power.
Model E676
Available only in "Briarwood" (tan), the E676 also used the same circuitry as the E670.
Model E678
This portable model uses five tubes plus a selenium rectifier, and operates on AC or DC current, or on batteries.
The set receives the AM band plus shortwave from 1.7 to 3.4 mc.
The cabinet was available in four colors: Suntan, Sealtuft Gray, Sealtuft Green and Sealtuft Tan.
Model E740
Seven of Philco's table model radios for 1957, including two of its clock radio models, all use the same five tube circuitry and receive the AM band only.
This is one of those seven models - the E740.
The cabinet was only available in black and ivory.
Model E742
Using the same five tube circuitry as the E740, the E742 was available in pink or ivory.
Model E748
A six tube Philco clock radio which includes a jack in the rear to enable the user to play a phonograph or other audio device through the radio.
The set includes a Telechron automatic clock timer.
The cabinet was only available in ivory.
Model E808
Available only in Midnight Blue with an ivory grille, the E808 uses the same five tube AM circuitry as the E740 above.
Model E810
Very similar to the E808 and using the same electronics, the E810 came in two colors: Pink and Ivory.
Model E812
This AM-only table model uses identical circuitry to the E740 with the exception of the clock, which the E812 does not have.
The plastic cabinet was available in Aztec Gold or Spice.
Model E814
Another five tube, AM-only Philco table model, the E814 was available in the following colors:
Model E816
And this five tube Philco model was available in turquoise or ivory.
Model E818
This six tube, AM-only model uses two 4x6 speakers and includes a phono jack in the rear as well as a bass-treble tone switch.
The wood cabinet was available in blonde, fruitwood, or mahogany.
Model E976
Philco's only AM-FM table model radio for 1957, this set uses seven tubes plus a selenium rectifier.
The wood cabinet was available in mahogany, blonde, or fruitwood.
Model E1351
This portable phonograph uses one tube plus a selenium rectifier, and can play 33-1/3, 45 and 78 rpm records.
The cover can be placed under the unit as a stand.
The cabinet was available in two colors: Charcoal and Ivory, or Ginger.
Model E1353
Using a similar circuit as the E1351 above, the E1353 uses two speakers connected in parallel.
The unit can also play 16 rpm records in addition to 33-1/3, 45 and 78 rpm records.
This model was available only in tan.
Model E1355
This portable unit contains a one tube amplifier with selenium rectifier, and a three speed automatic record changer.
The cabinet is wood, covered in leatherette.
Model E1356
A three speed automatic record changer and an amplifier using two tubes and a selenium rectifier are the features of this portable model, which has a wood cabinet covered in leatherette.
The audio output is one watt; a four inch speaker is used.
Model E1357
The E1357 has a 4 x 6 oval speaker mounted in the removable lid of the unit. It has a two tube, one watt amplifier (with selenium rectifier), and a four speed automatic record changer that plays 16 rpm records as well as 33-1/3, 45 and 78 rpm.
Model E1358
This Philco model uses two 6 inch speakers, a two tube amplifier with 1 watt output, and a four speed automatic record changer.
Model E1360
This model uses a four speed automatic record changer, a three tube amplifier with selenium rectifier, and a conventional speaker combined with an electrostatic speaker.
It has separate bass and treble controls, and has an audio output power of 3 watts.
Model E1362
A compact floor model high fidelity phonograph which uses three tubes plus two selenium rectifiers. It includes an 8 inch speaker, an electrostatic tweeter, and an acoustic resonator.
The unit has an output power of 10 watts and includes separate bass and treble controls.
The wood cabinet was available with mahogany or blonde finishes.
Model E1363
Similar in appearance to the E1362, the E1363 uses a four speed automatic record changer with a four tube amplifier with 8 watts output.
It has an 8 inch woofer, an electrostatic tweeter, and a 6 inch acoustic resonator.
The wood cabinet was available in mahogany and blonde.
Model E1370
A three speed portable radio-phonograph with a five tube AM radio which has an audio output power of 1 watt.
Model E1762
A larger floor model phonograph, it uses the same circuitry as the E1362 above.
The cabinet was available with mahogany, blonde or fruitwood finishes.
Model E1763
Available in blonde or mahogany, this high fidelity phonograph uses the same circuitry as the E1363 above.
The speakers used are an 8 inch speaker and an electrostatic tweeter.
Model E1764
Using an electrostatic tweeter and a 10 inch woofer, this model was otherwise identical to the E1362 above.
Model E1765
Another Philco high fidelity that is electronically identical to the E1363 except for the 10 inch woofer used with an electrostatic tweeter.
The wood cabinet was made with mahogany, blonde, fruitwood and teakwood finishes.
Model E1766 "Phonorama III"
The 1957 Phonorama III includes a five tube amplifier with 30 watts maximum output (20 watts with less than 2% distortion).
A four speed automatic record changer is included.
This Phonorama did not include a built-in radio; however, an input jack for an external tuner or tape deck is provided.
Model T-7
Philco's first transistorized radio uses seven transistors and operates on batteries. Most models were made in an ivory cabinet with black trim; a less common cabinet version is "Redwood" (red with ivory trim).
The speaker grille is made of thin metal that is very fragile; simply picking the radio up while placing a thumb or fingers on this grille can cause dents in it.
A leather carrying case was available as an option for this model.
