Philco 37-630
Was looking at a Philco 37-630/650 and asked some more questions and the seller says it has 8 tubes but is a 37-630 which doesn't make sense since the 630 should have only 6 tubes and the 650 should have 8. Were the cabinets similiar enough so that it may be a 37-650?
The console versions, which I know you are referring to, are very similar in appearance. The 650 is a bit bigger, though. Plus, you can also tell the two apart by looking at the trim at the top, along the sides curving around to the front - it is flat on the 630, but has a groove in the 650.
You could always ask for a photo showing the back view of the set...hopefully it wouldn't be as dark or fuzzy as the one the seller has posted of the front of the set...
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1203 online users. [Complete List]
» 6 Member(s) | 1197 Guest(s)
AvatarAvatarAvatarAvatar
