39-6ci
i've seen the pics here but i need a side view,are the sides white also?
mine has been completely stipped and i need to repaint it,i can see the black trim on the front on pics here,thanks,phil
Hi
Can't help you with side views, but I can tell you that the sides and top are also ivory, as is the front (note: ivory, not white).
Trim is black, as you noted.
Hope this helps.
howdy ron,good to here from you. is antique ivory a good match? i have a spray can that i used on a belmont 6d111 that matched perfectly,thanks,phil
Well...if it looked good on the Belmont, then it should look well on the Philco. Icon_smile
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1260 online users. [Complete List]
» 1 Member(s) | 1259 Guest(s)
