90 dial drive mechanism repair
The 90 that I'm working on has a very sloppy dial drive mechanism; the shaft has a little slot worn in it, and the matching hole in its bracket is worn, too. I have some ideas from old posts on the ARF, but I thoght that I would ask here.
Tim KA3JRT
I fixed it; I found an old hollow tuning shaft (to use as a bushing) in my assorted junk (probably a shaft from one of those late 40s Zenith sets), which had a quarter-inch I.D. I slid it over the tuning shaft, and carefully centered the shaft over the original hole. I used a fine-point Sharpie marker to draw a circle around the new bushing, and reamed/filed the bracket to the diameter of the bushing. I then pressed it into place and soldered it, trimming the new bushing to about one-quarter inch or so. The dial was then reassembled, and the mechanism was oiled. It now works perfectly, and should be good for another 74 years.
Tim KA3JRT
Hey Tim, don't leave us in suspense....
Could you add some pictures please? Icon_smile
I’m making progress with the alignment. It was a combination of needing to solder the connection on pin 3 of the BC osci...jrblasde — 10:21 PM
Mr. Fixr Compared to you I am sooo green behibd the ears...I have about 40 or so sets.morzh — 07:12 PM
48-482 rear panel help
Many thanks to all for the responses! No plastic button "covers" on my radio. Ron, thanks for the chapter on...keithchip — 05:53 PM
I am back to working on this radio and managed to get a couple of radio stations to come in. But can someone help me to ...osanders0311 — 01:58 PM
Hi Kettlechip and welcom to the Phorum. The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
There are currently 388 online users. [Complete List]
» 2 Member(s) | 386 Guest(s)
