Threads: 338
City: lawrenceville nj
Threads: 310
City: Kings Park NY
Heyo!
Resolve carpet cleaner, a nylon brush( or toothbrush), and plenty of elbow grease.
Not working?...try some Zep foaming glass cleaner.
Take the cabinet outside and spray it down heavy.
Me
AC: 4 DC: 1
(This post was last modified: 09-25-2015, 07:59 AM by OldRestorer.)
Threads: 19
City: The Motor City,Detroit MI
If you dare, try Castrol Superclean. It's a purple fluid that is basically Easy-Off oven cleaner (lye) without the foam. It's very aggressive. Test it on a small, inconspicuous spot first.
I cleaned up the cloth on a Canadian Marconi portable but trying a bunch of things, in it's case it had black greasy dirt like dried up motor oil all over the top. First I used some gojo hand cleaner, but I think I also used mineral spirits, alcohol, TSP, and finally lacquer thinner. Eventually I painted over the cloth with Watco lacquer to restore the doped look. I would start with Gojo and see where that takes you, but carpet or fabric cleaner may help if that doesn't work. Another option if it's really bad is brake cleaner, which is perchloroethylene in a can, the same stuff used at the drycleaners. Keep in mind that this cloth is doped, meaning it's clear coated with a varnish or lacquer, so if you go too crazy with chemicals you may have to recoat it.
Threads: 338
(09-26-2015, 05:11 AM)Arran Wrote: I cleaned up the cloth on a Canadian Marconi portable but trying a bunch of things, in it's case it had black greasy dirt like dried up motor oil all over the top. First I used some gojo hand cleaner, but I think I also used mineral spirits, alcohol, TSP, and finally lacquer thinner. Eventually I painted over the cloth with Watco lacquer to restore the doped look. I would start with Gojo and see where that takes you, but carpet or fabric cleaner may help if that doesn't work. Another option if it's really bad is brake cleaner, which is perchloroethylene in a can, the same stuff used at the drycleaners. Keep in mind that this cloth is doped, meaning it's clear coated with a varnish or lacquer, so if you go too crazy with chemicals you may have to recoat it.
thanks guy`s
I thought it was some kind of nylon or plastic
so it`s cloth with a coating
will have to experiment with crappy one first
sam
Threads: 338
Hey guys
Tryed Capet cleaner and zep
On a junk cabinet
Now has spots and still seams dirty
Are they spouse to be yellow Or orange
The look to be orange color
Sam
Threads: 114
City: Sneedville, TN
From the look of it it is just a bit dirty, as mine was. I just cleaned it with a brush and dish soap in warm water, and wiped off quickly with a rag. Of course, the original finish will remain, which will be yellowed as all old varnish is, but it will look decent.
[Image: http://41.media.tumblr.com/34e930da94263...2_1280.jpg]
With a varnished cloth cover like these, I think using as gentle an approach as possible is best. Good luck with yours.
Grundig 5088
| Skip,
you are back to this one?
Grundig 5088
Skipvecher — 09:17 PM |
| Have a touch lamp even off causes a problem up to 30 feet from the house have to unplug the monster. DavidDavid — 02:45 PM |
There are currently 2535 online users. [Complete List] » 1 Member(s) | 2534 Guest(s)
