Estate sale find: Philco 48-1256
(02-02-2016, 04:16 PM)captainslack Wrote:  Still not sure if I want to tackle the phonograph, though...
It's easier than you might think!  It was my first vintage phonograph and it was just about a breeze!
[Video: https://m.youtube.com/watch?v=gl2d5XoTdIg]
A friend left a Philco 48-1256 in back of my truck that she had found that someone had thrown out. I restored it- New gromets on the motor mount and the base platform for the phonograph, Put in a new speaker, soldered a few wires for the radio. Restored the finish on the cabinet. Put new stickum paper on the platform for the phonograph. Put in a new radio dial turning cable. Cleaned out the spider webs. It looks good, it turns on. But all I get is a loud buzzing on the speaker whether radio or phonograph is turned on. I haven't gotten a record to try the phonograph yet. And I need to hook up to an antenna for the radio to pick up any station. A puzzling thing is there is no volume control. How much do you think it will be worth in good condition?
Welcome to the Phorum, Wesley! The capacitors (paper and electrolytic) and any out-of-tolerance resistors need to be replaced prior to plugging the set in again. Serious damage can result from powering up 80 year old components. This isn't a radio that will make you rich in the end. Philco had many radio-phonograph models on the market, and this was only a Broadcast Band receiver and 78 rpm record changer. All said, a solid "meat and potatoes" radio, but not a diamond in the rough. Still worthy of restoration. Take care and BE HEALTHY! Gary
It is always best to start a new thread rather than revive one that is 10-years-old.
It is a restoration project; you should not turn it on before going through it with full re-cap (changing all paper and electrolytic cpaacitors).
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
Need to purchase Old Philco Radio Knobs
Hello Paulo , I have Philco 38-10 too that I am restoring the chassis is almost complete ! Far as my cabinet It is in ...radiorich — 09:00 PM
