Model 46-1209
Hello - I'm wondering if anyone has any comment on a Model 46-1209. I haven't looked at it yet but have a photo and a $45 asking price. I believe it has a phonograph in the front panel. Is the phonograph typically difficult to work on or get parts for? Any comment is welcome. Thanks.
Rod Basham
Hi Rod,
The typical issue is finding a replacement cartridge and perhaps the drive puck (rubber wheel). I would anticipate it may run $30 each. Also it probably only plays 78rpm records. A lot of older consoles in the 50's got the original turntable exchange for the newer 3sp tables. Don't know if the 78 player is a must but will add a bit of cost to the price tag.
ps. After consulting the diagram I noticed that it uses a mag cartridge. i think this is the model that uses a very hard to find styles.
(11-04-2015, 10:54 PM)Radioroslyn Wrote:  Hi Rod,
Yeah that would be a D-10A changer.  That is the version with the magnetic cartridge.  I think you're right about styli being hard to come by.
Well, I'll take a look at it and maybe I can locate replacement parts. Got a few radios on my platter right now anyway. Thanks for your input, folks.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 848 online users. [Complete List]
» 1 Member(s) | 847 Guest(s)
