38-116 broken wire in sub-chassis
Hi Terry,
Checked voltages on both 6L6 tubes and are as follows.
Tube 1
Pin 2 6.5 ac
Pin 3 220v
Pin 4 244v
Pin 5 -7.4v
Pin 7 checks 0 volts ac(should be 6.3)
Tube 2
Pin 2 6.5v ac
Pin 3 243v
Pin 4 244v
Tested both 6L6 tubes also,
Tube 1 checked 4000 (mut cond = 5000)
Tube 2 checked 3500
Pin 5 -31.6v
Pin 7 checks 0 volts(should be 6.3)
High voltage a little low
6.3 ac missing on pins 7
Irregular voltage on pins 5
Tubes check low on my hickok tester.
What do you make of this?
murf
(12-09-2015, 09:47 PM)murf Wrote:  Hi Terry,
Tube 1
Pin 2  6.5 ac
Pin 3  220v
Pin 4  244v
Pin 5  -7.4v
Tube 2
Pin 2  6.5v ac
Pin 3  243v
Pin 4  244v
Tube 2 checked 3500
Pin 5  -31.6v
murf
Hi Murf,
Well, The mismatch between the two control grids is a problem. According to the  RCA tube manual it should be close to -22vdc. Would check the 10K resistors in series with the grids and two secondary winding of the driver transformer, you may find one is open.
Restoring Philco 96
There are currently 2427 online users. [Complete List]
» 2 Member(s) | 2425 Guest(s)
