Talking House Transmiter
I wasn't sure where to put this but since it related to my Zenith - here it is:
I can remember posts about poor audio quality from these transmitters.
I have had one on the shelf for years. Got it out today to use with the 1000Z (see recent post).
Works great with my Samsung phone which I don't want to leave behind - very distorted on my old Blackberry. You can't turn the level down low enough not  to over modulate. I'll either have to pad it down or use another device. I have heard this complaint before but never tested one to find out why.
Somebody may have already figured this out. But just incase it can help. Seems like the stated 500mv input is wrong.
EDIT - seems that the advertised AGC might be active only in the "cal" mode. So retune the freq and then set it back. It will force it to calibrate.
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
There are currently 959 online users. [Complete List]
» 2 Member(s) | 957 Guest(s)
