Philco Console 37-61
Philco Console 37-61...Would a regular (todays) speaker work on this or does it have to be a tube amp speaker...
the original has 3 wires wound together---what would happen if a regular speaker was connected to the old wiring..I was told a regular speaker would make a loud humming noise..
Hi
The original speaker used in your Philco was an electrodynamic type, which used a field coil (electromagnet) instead of a permanent magnet, to produce a magnetic field which makes the speaker work. Of course, permanent magnets now perform that job which do not require electrical energy to produce the magnetic field.
This field coil is, often, part of the radio's power supply; specifically, it is used as a filter choke in many applications. This is the case with your 37-61.
Yes, it can be replaced with a permanent magnet speaker...but then, you also need an audio output transformer to match the audio output of the receiver to the voice coil of your replacement speaker...which will be a different value than original. In addition, you have to replace the resistance of that original field coil with something. A power resistor, 1000 ohms @ 25 watts will work as a substitute for the field coil, but you may have to increase the value of the set's electrolytic (filter) capacitors to make up for the increased hum due to the loss of the field coil.
48-482 rear panel help
Hi Kettlechip and welcom to the Phorum. The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
There are currently 367 online users. [Complete List]
» 3 Member(s) | 364 Guest(s)
