Philco 90 Lowboy
I have been working on the Philco 90 for the last couple of weeks, burning up a little vacation time.  So far, I re-stuffed all the bakelite blocks and replaced all of the resistors that were out of tolerance.  The primary of the first detector transformer was open, so had to rewind that.
That said, when I went through the alignment, the IF tuned up just fine at 175 kHz. When doing the RF portion of the alignment, both ends (600 kHz and 140 kHz) peaked, but I find the high end to be noticeably weaker than the low end of the band.  Is that normal for one of these receivers?
When checking the tube socket voltages, what is the correct meter ground connection point? Is the chassis the correct reference point, or the transformer center tap of the rectifier plate winding?  The Philco service literature I have does not state a reference point, it only refers to an AC Set Tester.
Thanks
Chris H
N9WHH
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
There are currently 1512 online users. [Complete List]
» 2 Member(s) | 1510 Guest(s)
