low volume on Philco model 20
I just got this radio and all tubes are good. I turn it on and the volume is all the way up - you can hear it, but its low. When I place my hand on the volume control, the volume goes up - or if I touch the chassis at certain points. What should I look for? Thanks, Phil
Have you replaced the capacitors on this set? Even if it is not humming, I'll bet an open capacitor is just begging to be coupled to the B- or ground. Of course it could be that the volume control needs a good shot of De-Oxit oe othr cleaner to clear it out. Start from here, and let us know what you find.
You should also check the continuity of the RF coils. If one is open...especially the first RF coil...this could cause the symptoms you describe.
Thanks to all - I'll check the RF coils first. Phil
All RF coils are good - next?
Next, check capacitors as Codefox suggested. Have they all been replaced?
Check continuity of the two sections of the volume control.
Check wiring between tuning condenser and the various RF coils. They are known to come loose over time, at the tuning condenser.
And finally, check your 24A tubes - are they good?
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
