Band Switch Repair
Some observations concerning band switches.
http://www.russoldradios.com/blog
What's the worst that can happen?
Though the subject is not a Philco, generally the observations apply except that I have not seen a Philco with flexible wire leads/contacts.
Thanks for the info Russ!
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1052 online users. [Complete List]
» 3 Member(s) | 1049 Guest(s)
