39-70 Panel Issue
Hey everyone. Ok, so I bought a Philco 39-70 radio to redo for my husband for Christmas. I am currently in the process of stripping it down to bare bones and have already hit a snag. Ugh
Is there a trick to removing the panel? I have removed all visible screws and it wiggles but will not come out! Cloth and tuner cover already removed.
Would love any advice, tips ... whatever. LOL.
THANKS
Welcome to the Phorum!
Icon_wave
Are you working on the 39-70B that looks like the one in the photo on this link? or the console model that is just below it?
Just to be clear...this is a battery operated model not one you plug into the wall.
Not sure which panel you are having trouble with. Chassis usually (I've not worked on a 39-70) comes out by pulling off the knobs, unscrewing the bolts or screws from underneath the cabinet and sliding the chassis out. There is usually enough wire to allow the speaker to remain in the cabinet while you do this. Then you can undo the nuts holding the speaker to the cabinet and pull it out. then the grill cloth board (often cardboard) and grill cloth are sometimes tacked, stapled or screwed to the cabinet. You've probably already done all this if you have the cloth out.
A picture of the remaining panel would be helpful unless someone else can answer ... here's how to post a pic. http://www.philcoradio.com/phorum/showthread.php?tid=29
Keep posting your questions to this thread, folks will be happy to help.
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 3696 online users. [Complete List]
» 1 Member(s) | 3695 Guest(s)
