Philco 38-624, possible substitute chassis and speaker
I have a Philco 38-624T with a nice "bullet" cabinet.  It has the 6 volt chassis that I believe is restorable but since I am not interested in the battery option I am looking for another Philco chassis and speaker that operates on 120volts and would fit in the 38-624T cabinet.  I posted about this over on the antiqueradios forum and was referred to this post on this phorum http://philcoradio.com/phorum/archive/i ... 13940.html.  If I read this post correctly it looks like the only options are the 37-610T, 37-611T, and 38-620T.  Are there any other options?
Thanks, Bob
I am currently in the middle of doing just what you are describing.
The only difference is, my 38-624T cabinet was empty when I purchased it.
I'm in the midst of restoring a 37-640 chassis. When finished I plan to install it into the restored 38-624T cabinet.
Here is a list of AC chassis that will fit in that cabinet:
37-610, 37-620, 37-630, 37-640, 37-2620, 38-610, 38-620, 38-630, 38-2620, 38-2630.
And a list of AC/DC chassis:
37-611, 37-641
Thanks Ron.  What about speakers?  Will the speakers from any of these models fit?
The speakers will need to be 8 inch units, matched to the chassis in question.
If you go to the following link here on the Phorum:
http://www.philcoradio.com/phorum/showth...hp?tid=215
and look for the Excel file speakers.zip, download and unzip it, and study it carefully. It gives information on the speakers used with each Philco model.
Thanks again Ron.  I just looked at the links to your restoration.  Great work and it will help me immensely.
Bob
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1006 online users. [Complete List]
» 2 Member(s) | 1004 Guest(s)
