Cabinet rubber cushion replacement
I am a new member.  I collect Philco radios as well as others.  While working on cabinets I'd like to replace old or missing rubber cushions on the bottom.  Any recommendations on web sites for sources?
Hi and welcome!
Renovated Radios should be your first stop for these parts.
http://www.renovatedradios.com/parts.html
Appreciate the guidance.  Thank you !!
Welcome to the Phorum!
Icon_wave
On the cabinet bottom or the chassis bottom? For the bottom of the cabinet you can find those in most hardware stores or home improvement centers, sometimes even dollar stores. For the corner cushions of Philco chassis Renovated Radios is one outlet, Radio Daze another, since it's a specialty item. If it's the generic large rubber washers there are a number of sources for those, AES has them, as does Radiodaze and Renovated Radios, other source might be McMaster-Carr or fleabay.
Arran --- Thank you for the guidance. I actually need those under the cabinet and will check out HD or Ace. But appreciate the other recommendations also.
Cordially
Mike
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 2116 online users. [Complete List]
» 2 Member(s) | 2114 Guest(s)
