Philco 118 Shadow Meter and Resistor
I am working on a Philco 118 and I can NOT find resistor 76  ( 2900 ohms in parallel with the shadow meter ). Is the resistor possible inside the shadow meter? What is the  resistance of the shadow meter winding?
Best Wishes
nv3g
Oscar
Don't think it's inside. The coil resistance (depending on the type sm) is somewhere around 800-1500 ohms. Have seen some sets that show a resistor on the diagram but none to be found on the chassis. It might be that the lower resistance coil may not require the resistor, it helps decrease the voltage drop across the coil and will not disable the set if the coil goes open.
Terry N3GTE
Now I think I've got it!
