speaker replacement
I have recently started rebuilding my first Philco, it's a model 39-116.
I have replaced all the wiring, capacitors,but need a speaker. Anyone have one that works ? Can I replace it with a common 8 ohm speaker? I have the schematic but it doesnt tell me how many ohms or what the resistance is on the transformer that used to be mounted on the top of it.
Hi "mister"
I think your speaker is a 12 inch unit? It is electrodynamic, with no audio output transformer mounted on it. It has an 860 ohm field coil, and either a 3 or 5 ohm voice coil - a quick look through my stuff does not reveal the exact specs on this speaker's voice coil, maybe Chuck has this info?
It could be replaced with a modern PM speaker, but (1) you would have to add a 850 ohm, around 25 watt, resistor under the chassis; and (2) original-type speakers are not that hard to find; in fact they seem to show up on our favorite online auction site (eBay) quite frequently.
Good luck,
1939 Part Catalogue:
Speaker 36-1450
Type "H" 12" electro-dynamic
Voice coil impedance @400 cycles = 5.1 ohms
(this is NOT the D.C. resistance measured with a meter.)
Field coil 860 D.C. ohms
Thanks for the assist. I have the earlier part catalogs through 1938, then 1941, 1946 and a couple of later ones - the 1941 and 46 catalogs show that speaker as still being available for purchase at that time, but do not give its specifications.
Thanks for the fast reply guys. I'll be checking Ebay.
46-1213 Schematic Question
In the photo of my Chassis, I now have two wires marked "A" and "B", these are my power cord wires. ...MissouriLarry — 02:46 PM
Gary, Thanks for the reply!  I have no intention of introducing any electric to my radio until I recap it.  I just want...MissouriLarry — 02:14 PM
Hi Larry, Usually you'll want to attach the hot side of the power line cord to the power switch. That way when the s...RodB — 02:06 PM
1934 American Bosch 440T restore on YouTube
That's an interesting radio Buzz! Great first video also...Eliot Ness — 01:59 PM
Hello Larry. Replacement of the power cord is a priority, but not the first. All paper and electrolytic capacitors nee...GarySP — 01:36 PM
Ok, now is time to post my first question.  I have a Philco 46-1213 that I am going to start working on here real shortl...MissouriLarry — 12:48 PM
Well, never enough yet how much is too much? I ordered some spare parts from a couple vendors in China and now have ship...TV MAN — 10:49 AM
This Marconi was a bit of a challenge. It was totally missing one electrolytic  capacitor, and the photos show a couple ...Dan Walker — 10:48 AM
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
