Philco 39-7 can capacitor
I have Philco 39-7 and it is missing a can capacitor. The can capacitor is actually an mdf 300v Electrolytic capacitor 30-2327. I have been looking for quite sometime to get a replacement (a non working replacement will be fine) as I have re-capped the radio. While I am still looking for it, I have also thought about trying to reproduce it as best as I can however I was wondering if anyone has done reproduction of such can capacitor? Thanks.
I'm thinking not on the repro. It's a bit of an odd size, smaller in dia w/a nut on the bottom. I would solder a replacement under the chassis. Or if you happen to get out to any large radio swap keep your eyes peeled for one the correct size. Other manufacturers used similar sized ones so it could be possible to find one on a non Philco chassis.
To keep things simple you can replace both caps w/10mfd @ 450v.
Which version do you have table or chairside??
Happy hunting!
Now I think I've got it!
I've made several fake cans for radios that are missing their can caps. I've usually been able to find PVC pipe about the right diameter and cut it off the right length. Any fairly stiff flat plastic will do for a top. Just cut it as perfectly round as you can, glue it to the top, and finish it with sandpaper, a file, an Xacto or whatever it takes.
Spray it with aluminum paint from the hardware store.
Some of the guys at my local ACE hardware store are interested in my radio projects, so they're willing to cut the PVC for me from scrap and sell me just the short piece I need. Their cut is straighter than one I could make with a hand saw.
If you are trying to fake one with the large nut on the bottom, you could just glue the painted fake cap to the chassis. If you don't want to glue it to the chassis, maybe you could glue some concentric PVC pipe pieces into the bottom side to reduce the diameter (below the chassis where it won't be seen) and then glue in a bolt so it would be like the orignal. With washers and a nut, you can probably find a way to hold it in.
The fake capacitors I've made have been realistic enough to pass a casual inspection. I've usually put the replacement electrolytic inside the fake can, but you could just mount it underneath, like Terry said.
Unfortunately the slender, single value caps that Philco used just before the war had a rolled perimeter around the top, so putting a flat top on, like I did, wouldn't look exactly right. It might be better than to have an empty hole, though.
John Honeycutt
