Model 20 case restoration question
Hello,
Can anyone tell me if the model 20 cathedral had toner shading along the edges on the front and sides. The cabinet is a nice walnut veneer and looks great with just a dark walnut stain and lacquer finish but pictures I have seen seem to show a dark shading along the edges of front and sides. If so what Mohawk color and product would be best to add the shading? Dark Walnut? The transparent toner? Thanks for the help.
Charles Yancey
540-649-1403
That would be the correct shading, I think it has some shading in the grille too. it might make sense to use something lighter then extra dark walnut and get it to the right shade in repeated coats. There must be a medium walnut, if that doesn't work use brown mahogany, it won't look reddish with enough coats.
Best Regards
Thanks for the follow-up information. I will try and use a medium walnut and see what that does. I may try and get the dark Mahogany as well. Thanks again!
Charles Yancey
For what it's worth, here's a link to a photo of my DeLuxe 20 with original finish, showing the toning. I can't say if the regular 20 panel is done the same way, but I suspect it is.
[Image: http://antiqueradios.com/gallery/d/47796-2/3philc20.jpg]
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1207 online users. [Complete List]
» 3 Member(s) | 1204 Guest(s)
