Philco 18 volume pot cleaning??
Hello all, I have my volume/on-off switch apart; part # 33-5024. I had to clean the on/off switch which wasn't working. It is now, with some contact cleaner. What would be the best to use on the carbon volume portion of the switch? Contact cleaner, alcohol, acetone? I heard some chemicals ruin the carbon resistor wafer. Please let me know, thanks!!
No acetone.
Alcohol works fine where you could see the contact and clean it with a swab; else use a clener. Deoxit D series is good.
I use WD-40. It's pretty mild and leaves a coating over the carbon. With that being said some pots are just worn out cleaning isn't going to restore it's operation.
I've been working on a 39-80 that the control was very noisy and the switch contacts measured open. Took it apart used contact cleaner on the switch and a little WD-40 on the pot. Tested it on the ohm meter and looked good. Installed it and worked great for a couple of days then I couldn't turn the volume down all the way. Checked it over and the ground side of the pot to wiper was about  50K  (should have been about 100 ohms). Basically it's open at the ground side. Have been waiting on Old Radio Parts to get a replacement.
De-ox-it FADER LUBE . It is in the green labeled can NOT the contact cleaner.
Thanks guys!!
sorry,
misread the part where the switch HAS been cleaned and the carbon part is being cleaned.
Yes, what Russ said. Deoxit Green, fader lube.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
There are currently 1492 online users. [Complete List]
» 1 Member(s) | 1491 Guest(s)
