model 40-200
Good Morning: When my father passed away he left an old philco model 40-200 to me. I am not sure if it has any value. It is in good working order. I would appreciate any advice on this.
thank you
Sundance
That radio is probably worth more to you as a memory of your dad than money. Consoles of that era usually are only about 100 bucks or so depending on how bad someone wants it.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 406 online users. [Complete List]
» 3 Member(s) | 403 Guest(s)
