Philco Model PT-27
I just finished rebuilding a Philco model PT-27. I believe I have a problem with the antenna coil. The radio will receive station when the antenna is connected to the to the control grid of the 7A8. When the antenna is connected to the antenna coil nothing comes through. The coil has 30 ohms on the tuner side and 2.8 ohms on the antenna side. Is this a bad coil.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 417 online users. [Complete List]
» 3 Member(s) | 414 Guest(s)
