Chassis rubber washers for 16B?
Was wondering what the correct rubber chassis washers are for a 16B tombstone 5 band that the chassis sits on in the cabinet? Thanks!!
Those are available from Renovated Radios.
http://www.renovatedradios.com/product.php?product=296
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
That link is to corner mount feet, not round washers...
If you look around that site you will find them. this is a link to the Philco page: http://www.renovatedradios.com/productli...ondary=114 . Measure the ones you have, and find the closest ones to it.
Sorry, I'm working on a 16 tombstone that does use those corner rubber pieces. I'm guessing other versions of that model used a different chassis washer mounting system. Dunno
Blessings,
Jeff W.
Jonesboro, Arkansas
These?
No, my chassis must use round washers because there are recessed round holes in the cabinet floor where they would go... they where gone when I got the radio and just want to make sure I order the right ones so the chassis height is correct for the control shafts to fit through the front panel correctly...
I may have stated wrong too on the cabinet... Mine is the second design, right after the cathedral version, with the flatter top... it is a 5 band code 121...
If the height is a bit off, couldn't you add a washer or two?
Simple.
Measure the diameter of the recessed round hole.
Go to Renovated Radios and find the chassis washer closest to the size you measured (but not larger).
Order four of them.
When they come in, place them in the recessions, put your chassis in place being careful not to move the washers, then learn more colorful words as you attempt to get the chassis bolted back in. Icon_eek But you can do it, you just have to be patient and not get in a hurry.
You can also get them from AES and Radiodaze, AES seems to have better prices though, and they sell Solen non polarized caps which are useful for replacing electrolytic caps, permanently . www.tubesandmore.com
(03-06-2019, 03:42 PM)Ron Ramirez Wrote:  Simple.
Order four of them.
Icon_lol
Seriously... I use a little piece o double stick tape for this...
Not a bad idea...
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 3006 online users. [Complete List]
» 2 Member(s) | 3004 Guest(s)
