645 Chassis in a 640B cabinet?
I have a orphaned Philco 645 chassis, speaker with escutcheon from a console. I have an opportunity to pick up a 640B cabinet only. The 645 is 3 band while the 640 was 4 band. I was wondering if the 645 would, first, fit the 640B cabinet and second, if the dial would line up properly with the escutcheon opening? I would use the 645 escutcheon. I know the speaker probably would not fit Icon_wink
The 645 chassis will fit perfectly inside the 640 cabinet.
Interested in a trade? I have a 645B cabinet I wish to keep. Having no 645 chassis, I stuck a 650 chassis inside.
The 640B and 650B cabinets are the same.
PM sent.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 403 online users. [Complete List]
» 3 Member(s) | 400 Guest(s)
