My 38-10
This Beauty is on my bench right now..the tuning gang has lost it's rubber
pieces that isolate the gang from the chassis..is there available new rubber pieces,or else does someone have a good fix for this dilemma?
Am also looking for Ron's book--no can find Icon_sad Icon_confused:
The book is now out of print.
I have used large rubber grommets to repair the tuning condenser mountings in certain 1938 Philcos,and I believe yours falls into this category. Basically, when mounted, they take on an oblong appearance but do the job just fine.
Tubenutt, something I did on a Silvertone's tuning gang that was isolated from the chassis I used faucet washers that I got from the local hardware store. To isolate the post I used black shrinkable tubing then opened the hole out in the faucet washer to slip over the tubing that was now shrunk onto the mount screw shaft. I would have to look at my donor 38-2 chassis to see how they are mounted since it also has the magnetic tuning that your 37-10 has. oops I noticed it was a 38-10 and not a 37-10, no magnetic tuning on the 38-10 as far as I know.
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1207 online users. [Complete List]
» 5 Member(s) | 1202 Guest(s)
AvatarAvatarAvatarAvatar
