Philco radio
Hi all and thanks for letting me join.
  I have a possibly unanswerable question, but here goes.
When I was 7 or 8, one of my brothers brought home a Webcor 78 changer, a collection of children's records and what I think was a Philco radio that the record player plugged into. I still have the changer and the records, but the radio is long gone.  If I am remembering correctly, the radio was in a vertical cream plastic case with, I think, a brass handle, and the changer plugged into a phono jack on the side. This would have been sometime in the early 50's.
Anyone know what the radio might have been?
Thanks
Thom
Thom,
Welcome!
Honestly, my knowledge of Philcos is mainly 1930s, but we do have a Gallery, listing and showing models by year. Take a look and see if you spot it.
Philco Gallery
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 698 online users. [Complete List]
» 1 Member(s) | 697 Guest(s)
