Threads: 142
City: Lansdale
State, Province, Country: PA
ALL, Have a zenith that the Rectifier is open SE-1.. I was going to replace it anyway But what do I use?
Would a 1N4007 work? or do I need something different..
[Image:
https://live.staticflickr.com/65535/5051...4e62_c.jpg]
Here is schematic partial..
[Image:
https://live.staticflickr.com/65535/5051...ed56_c.jpg]
PS one other question There are a few resistors marked WW I assume that means wire wound Do they have to be wire wound?
Thanks
Skip
Threads: 55
City: Roseville, MN
Yes, you can use the 1N4007. You will have to increase R20 to around 33 to 47 ohms to get the B+ down to 90 volts.
Threads: 437
City: Boston
Maybe leftovers from World War 1, resistors.....
Threads: 142
City: Lansdale
Ok I heard or read somewhere that the selenium Rectifiers are marked backwards.. that the Plus marking is the Cathode and minus marking the Anode..Is this true? if so how does the 1n4007 go in..
Skip
Threads: 270
As far as I've seen no they are marked properly. The + is where the positive voltage exist the rectifier. The ring (cathode) on the 1n4007 goes to the + side of the filter cap.
Now I think I've got it!
(This post was last modified: 10-21-2020, 09:41 PM by
Radioroslyn.)
Skip
You are right, Plus is the Cathodes. Because Plus in teh Seleniums shows the Output Voltage polarity, not the Pos/Neg Electrode (Anode Cathode), as the Diode or teh Bridge has Positive Voltage coming out from Negative Electrodes (Cathodes).
So, in Seleniums, the B+ (and the positive of the electrolytic cap) will go to the pin marked "+" and the one marked "-" will go to the negative (and possibly Chassis in he later models).
Threads: 41
City: Wellborn Florida
Guess I am the red headed stepchild!
Threads: 226
City: Omak
State, Province, Country: WA
hello morzh,
I am sure more then once people have hooked that diode up in backwards and really made a mess.
Sincerely Rich
P.S. look at some the old electrolytic capacitors the stripe is positive not negative !
Threads: 142
City: Lansdale
Ok Finished up the Capacitor replacement.. Replace some resistors also.. Brought up on variac .. at 120 Volts B+ is 90.5 volts..I used a 40 Ohm resistor.. at 120 Volts draws less then 300 ma.. So all is good there.. ON FM band stations come in load and clear all over dial.. BUT on AM only receive 1 station and only when I put my hand near the loop antenna..
Hopefully all it needs is a alignment on AM .. Any comments?
Thanks
Skip
Threads: 437
City: Boston
Is antenna connected properly? I had a Zenith, played pretty good FM but a weak wire to antenna left AM very weak.
It was obvious but I overlooked it.
Threads: 142
City: Lansdale
Good thing to check..I label everything.. but as you say its easy to get something in the wrong place..
I have to bring it to garage.. that's were all my alignment equipment is..
Funny thing I expected the AM to be good.. and the FM have some problems... But i am glad its not the FM...
Skip
Threads: 142
City: Lansdale
Ok Aligned the AM.. The IF's were way off.. Also aligned the dial..
AM now working correctly.. I did find a bad tube.. The 12AT7.. I did check all tubes on tube tester and all tested Good..
Like they say you don't know if a tube will or will not work in radio until you try..
So now both AM and FM working great..
Skip
Threads: 41
When working on AM/FM sets it is good to have several 12AT7 an 12DT8 on hand never know when they will be needed.
