Ampeg J-12D
Does anyone have any information on this amp.. I replaced all caps .. when i turn it on... no mic connected its quite .. no hum.. but when i plug in a mic i get a load hum when i turn up the volume its a metal case mic as soon as i touch the mic the hum comes.. any clue on why? grounding ??
Skip
https://ampeg.com/support/files/Schemati...ematic.pdf
Thank you very much, Arran. This is extremely useful information for me.RadioSvit — 07:54 AM
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
There are currently 965 online users. [Complete List]
» 3 Member(s) | 962 Guest(s)
