Philco 20 Speaker Mounting Bolts 3 or 4
I am working on a Philco 20 and the cabinet has 4 holes for the speaker. Three are now being used, but I have seen a few sets with 4.
It looks like there must be a bolt under the escutcheon for the dial. on the ones that I have seen 4, as otherwise there would be no place to mount the nut.
Is it just a regular bolt, leaving the three others as the ornamental ones?
You can see the three ornamental ones. But on some other sets I have seen--in fact all, there are four square nuts--presuming 4 bolts.
I did finally try down some square bolts from ACE True Value.
I looked at my Philco 20 Deluxe (basically the same cabinet) and there is a non-ornamental speaker screw under the escutcheon:
Value of capacitor
What is an OP?  Looks like the “OP” mistakenly typed electrolytic.  Lets forgive him.Joe Rossi — 06:31 PM
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
There are currently 1952 online users. [Complete List]
» 1 Member(s) | 1951 Guest(s)
