RESTORATION MODEL 57C
I have restored a 57C. The primary of the oscillator was cut off.
Who may be interested:
22 turns. 39 gauge.
Regards and good year 2022
Bet that was a job scraping it down to connect, kudos...
I use a nail file to scrape the enamel off the magnet wire. I place the wire on the nail file and my finger on top of the wire then I drag the nail file across the wire very carefully without much pressure on the wire a few times. I have tried burning it off with a lighter and it breaks the wire.
-Carlos
One can do the same thing using a small, folded over piece of 400 grit sandpaper Again, you don't want to use much pressure.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
There are currently 1407 online users. [Complete List]
» 3 Member(s) | 1404 Guest(s)
