#76
Tim, you refer to “AK”. Is that Alaska or Atwater-Kent, or… Joe
#77
It's the other forum. I'm also in DIY, but mostly read there. Honestly, I kinda jumped into this without much thought to my other equipment, and kinda having to re-learn some stuff. Hopefully I'll have a better baseline to compare upgrades (or downgrades) and changes. Right not, my radio room is no more. Tore it out to the bare walls! New thread coming on this.
Tim
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
