Philco 46-1226 Code 122 Schematic
Hello all,
I'm in the midst of restoring a 46-1226 Code 122. I have obtained several schematics - Riders, Philco service manual, but the problem is these all deal with the code 121 model, or if they address 122, it's just to list the changes that were made.
Problem is, this model had a rather large change, with the 7F8 converter replaced by a 7AF7, and with it, the wiring and circuity was altered quite a bit.
I'm in need of a schematic for the Code 122. I found one through the Radio Museum, but the quality is poor; almost bordering on illegible.
Does anyone have a fairly high resolution, clean image scan of the schematic? I'd very much appreciate any help.
Thanks!
BR
Welcome to the Phorum, BR! Someone here should have the info you're looking for. Take care and BE HEALTHY! Gary
Hello,
If you click on the PHILCO LIBRARY tab on the banner at the top of this site, then click on the SERVICE INFO tab it will take you to the Philco Service section (a drop-down menu).
Select the 1946 - 1947 Home Radio Year Book. Under the table of Contents you will find a link to the model 46 - 1226. This will provide all the published info from Philco for that model. The information includes pages 214 - 224 from the yearbook. The last page is a schematic for the 46-1226 code 122.
It appears to be a good clear copy.
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM
First Radio restoration
Hi, welcome. I did a 40-130 a few years ago. I was very surprised at how well it performed. Just take care with that sp...Stan the Man — 07:20 AM
Restoring Philco 96
Situations of the like are not pleasant. Life is inevitable. Best of luck to you. I have two 76 chassis, in different ...Stan the Man — 07:12 AM
