650X Logo Decal
Does anyone know of a good source for the Philco Logo Decal on a 1936 650X radio?  Radio Daze has them but they are selling 8 at a time and charging $6+ shipping for something that could be put in a 1st class letter.
I really only need 1.  Is it possible to potentially print something out out with a color printer and use that?
Thanks, Bill
Bill;
Is there anything else that you may need, the last time I bought decals from Radio Daze (or was it a dial?) it was with a bunch of other stuff like capacitors, wire, etc. I don't know who else sells decals. Maybe someone on here can supply you with one off of a sheet?
Unfortunately at this time, I do not need anything else. I found one on eBay for somewhat cheaper. ($7 vs. the $16 Radio Daze cost). Still kind of expensive for a simple decal.
I'm sure I have what you need. I restored my 650X several years ago and can check my stash of decals for the Philco decal.
15 minutes later:
Yes, I have them. I have 3 sizes, so I checked to make sure I have the size you need. It's right below the dial on the cabinet. Send me a PM with your address and I'll mail it today.
Here is a picture of the original.
That's the one I matched. It's on the way.
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
