41-300 Bias resistors
I'm going to start off by apologizing if this is a nooby question. All 3 of the bias resistors are blown on this set. The 150k resistor is larger than the 10 and 15, does it need to be a 1 watt or larger? There isn't a notation on the parts breakdown or the schematic. What would cause all three to blow? I found the 80 tube and both of the XXL's weak. I'm replacing all the crumbling wires but the only burn spot on the chassis is where these were located. Any help would be greatly appreciated, I want to make sure it doesn't happen again when I give it a test run. I have a nightmare that it caught on fire the first time I tried it (even with a variac)... Icon_lol
Thanks
Glenn
Happily back in Illinois..not.
I posted in the wrong location, sorry lack of sleep.
Ron, if you could move it I would appreciate it.
Done. Icon_smile
Excess current usually kills resistors. In your case, you are lucky; this set used individual resistors instead of a multi-tapped Candohm.
Looking at the parts list, it calls for 1/2 watt wirewound resistors to replace the three. I think I would use 1 watt units for the 10 and 15 ohm resistors, and 2 watts for the 150 ohm (note it is 150 ohms, not 150K). I suspect the part number for the 150 ohm resistor, 33-115336 (150 ohm, 1/2 watt, wirewound) is a typo since the actual resistor is larger than the other two.
Oh, and to prevent the new ones from failing, make sure there are no B+ to ground shorts or leakage before applying power.
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 332 online users. [Complete List]
» 2 Member(s) | 330 Guest(s)
