Fada 1000 Component Question
Hey all - got a possible dumb question.  What is this component?  Is this a wave trap?  This component is installed between the Loop antenna and antenna tuning condensor, and pin 4 of the RF Amp 12SK7.  Not shown on the schematic.  I'm thinking it is the wave trap relocated to the RF amp input instead of the oscillator input.  In any case it reads open resistance.  Feel free to dish some crap my way if this is a dumb question, I can take it.  George
Craftsmanship is an ongoing cycle of learning fueled by patience, persistence, and care, where every project refines our judgment and challenges our skills, in the steady pursuit of the Path to Mastery.
Hi SRv2,
No, no one should throw shade your way. The wave trap is between the mixer grid and ground. One would think that there would be a tuned circuit consisting of a gang of the tuning cap and a n appropriate coil (such as the secondary of the RF to convertor transformer) at the mixer grid, but this is a budget radio (or was a budget radio; collectors pay a mint for this now).
This may be a condenser or a bad (open) coil, or a bad (open) resistor. Unfortunately, run changes don't always make the schematic. For now, leave it out and connect the condenser and loop directly to the grid of the RF amp and see what happens; nothing will smoke.
Not all radios had this wave trap. I have several radios made in New York. The borough of Queens housed several radio manufacturers including Emerson, Grebe, FADA, Andrea Aladdin and others. Others were made in New York City (Manhattan). RCAs were built in Camden, NJ. These wave traps were often needed in areas with a lot of ship traffic, especially in the Great Lakes area, a major ship transportation area (Iron Ore, Coal, grain, etc.), as ship to ship and ship to shore communications for navigation and RDF were often on the Long Wave band and in the 420 - 480 KHz range, where the IF frequency of many radios fall. The only radio that I have that has a wave trap is a Coronado (Gamble Skogmo) battery farm set, likely sold for farms near the Great Lakes. Radios were built for certain areas. For example, there were 4 tube superhets (no IF amp, only IF tuned circuits) for the city, 5 tube superhets (The AA5) for suburban areas and 6 tube sets (The AA5 circuit with an added tuned RF amp) for fringe areas. Your set may have been built for the Great Lakes area.
Hope this helps.
MrFixr,
This helps a lot.  Mainly because it was not a wave trap, so my ego remains mostly intact. This unit has the wave trap on the schematic but it is nowhere to be found.  There are multiple component changes around the RF amp circuit, I'm assuming like you said a run change that didn't make the schematic.  This unit is from 1945, so I had gone through all my old Rider books before and after looking at Fada models trying to see if a schematic revision had been issued, no success.  The other reason I questioned it was due to not-too-great performance whereas I had thought a 6 tube unit with an RF amp would have done so much better than an AA5.  Like you said "budget radio".  This is my first Fada, and I'm not very impressed.  I would have saved myself some disappointment if I had just put it on a shelf in my home on display.  After working on this thing, I lost a bit of luster for my first Catalin unit.  Meanwhile I installed a jumper in place of this and aligned the radio best I can. It performs decently but the little Philco 49-500 I just finished has better sensitivity. NOW, I'll reassemble and put it on a shelf and stare at it.  Thanks for the feedback!
George
It's a small ceramic capacitor, even though it does look like a dogbone resistor. I'm not sure why it was used but maybe they concluded that there was a tracking problem at alignment and decided to slightly reduce the capacitance to the stator of the antenna section of the tuning condenser.
Take a C-meter to it, if it measure some hundreds of pFs and infinite resistance, it is a tubular ceramic cap.
I am a bit surprised as the grid then is floating, but then I see a wire going from the Grid where this cap comes to the #4 pin. Where does it go?
Hello George,
I agree with Mike that looks like a tubular ceramic cap!
I was able to dig out and get working my old Radio Shack multimeter that has capacitance and it reads 0.1 nf. I measured a bunch of other caps to ensure the meter was working. And to answer Mike's question, There is an added 1M ohm resistor from the grid pin 4 down to the other side of the antenna loop (parallel with the loop). These two components are not on the schematic. The radio functions well without this ceramic cap and a jumper in place of it. George
Hello George,
I sure that part is some where on the schematic unless someone added it .
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
There are currently 1910 online users. [Complete List]
» 1 Member(s) | 1909 Guest(s)
