1950s Gramophone & Radio combo video
Hello everyone,
Here’s a short video of a gramophone featured in an episode of The Repair Shop.
I have never seen one like this also neat to see it work after all those years .
[Video: https://www.youtube.com/watch?v=5DfEd5GxDfU]
Rich;
I have seen the episode with that set, there was also a table version without the record player. It's a post war G.E.C set, from 1947-48, no relation to U.S or Canadian General Electric, and impressive as it looks, disappointingly, only has five tubes. The pushbuttons are not for presets, that's the band switch, tone, and radio/phono selection. It's the same thinking that went into post war British TV sets, only had one channel on them, fix tuned, TV sets had no tuners until 1954, even the Soviets thought that TV sets needed a tuner. It's odd since they were very early adopters of nuclear power, even designing their own power plants, same with jet airliners.
Hello Arran,
Yes, that radio is odd like a hold over with that earlier turntable neat looking cabinet thou .
Rich;
Here is the table version of that combo unit, it looks like they basically built a console cabinet around the table one. https://www.radiomuseum.org/r/general_el..._4750.html
Hello Arran,
I like that cabinet design !
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
There are currently 2044 online users. [Complete List]
» 1 Member(s) | 2043 Guest(s)
