Philco 38-4xx Cone-Centric Auto Tuning
I may have to work on a Philco 38-4xx console. It has the Cone-Centric Automatic Tuning Mechanism and I'm wondering if anyone knows if this tuning mechanism is totally mounted on the chassis or is there some attachment to the cabinet/bezel. I'm hoping it comes out with the chassis all together as one.
I believe that you need only to remove the coarse and fine tuning knobs and that the "Bezel" (as opposed to the escutcheon which is a of the cabinet) and all else will clear the escutcheon and come out with the chassis. It appears that the mechanism attaches to the chassis with 4 bolts, and a setscrew for the capacitor.
This is a different mech than the "Magnetic" tuning, as far as I can tell. However, the magnetic tuning comes out with the chassis and can be separated from the chassis after removing 6 bolts and cutting 3 wires.
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
