04-14-2011, 11:19 PM
The on/off switch on this radio is not working. Can these switches be repaired? The volume control part of the switch is good.
Repair of on/off switch for 42-321
04-15-2011, 07:54 AM
Does it click when you turn it?
Terry When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
04-15-2011, 09:44 AM
Yes, it has a good solid click when turned on and off.
Bob
04-16-2011, 06:39 PM
Well unsolder it and carefully pry up the tabs that hold on the cover. Once you get the cover off spray the innards with DeOxit. Try this for starters and see if that does it. If not you can drill out the rivets that holds the switch to the cover. After you get it apart use a lite abrasive to clean up the switch contacts.Get some small screws from the hobby shop to put it back together. You may find the contacts are badly burnt that's time to find a new pot/sw.
Good Luck/w it Terry When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
« Next Oldest | Next Newest »
Users browsing this thread: 2 Guest(s) |
